I would like to create local tags to receive the output of Link Advanded tags.
The purpose is to synchronize the timestamp of several data with a trigger.
I did it with Derived tags - Trigger but when the valueof a tag doesn't change, the derived tag is not updated with the trigger occurs. So my OPC Client doesn't see the new event.
Thanks in advance.
At present there is no way to combine triggers with Link Tags. The only options are "On Data Change" or 'On Interval" I recommend opening a support ticket with the Kepware team so that they can analyze your specific needs and potentially come up with a solution. Here is a link to the login page where support ticket can be opened:
*Chris
