Description: I am using Thingworx Industrial Connectivity(Kepware) 8.3.65. Here it is connected with MQTT server by MQTT driver. But the it is getting disconnecting and connecting a very short interval.
Could you please share kepware logs , Application logs and communication and configuration logs files from \ThingworxStorage\logs folder from the time when issue occurred.
Abhishek
