Does anyone know if it is possible to read modbus device ID objects using Kepware's Modbus TCP/IP driver? I am referring to the data you access using modbus function code 43 (e.g. vendor name, product code, firmware revision, etc.). I can only find references to the four typical modbus tags types (output coils, input coils, internal registers, and holding registers) when browsing through the driver's manual.
@SW_10662463
The Kepware Modbus driver does not have this level of customization for this functionality. It may be possible to use the Kepware UDD driver to access these objects. I recommend opening a support ticket with the Kepware Solutions Consultants team to assist with UDD driver use. Here is a link to the login page where a support ticket can be opened:
*Chris
@SW_10662463
*Chris
Thanks Chris!
