Our company's custom MES application uses an Oracle database on the backend and connects with the shopfloor PLCs using the KEPServerEX OPC server. We plan to migrate the MES application (Full-stack - database + Middleware + UI) and the OPC server machine to Oracle Cloud. Below are the existing configurations:
Oracle database 12c Rel 2
OPC Server
As part of the migration, we want to upgrade the Oracle database to 19c and switch to the Oracle Autonomous Transaction Processing (ATP) database. We have set up the ODBC connection using the Oracle 12c ODBC driver and instant Client 19c (we also tried the 12c client). KEPServerEX can connect to the ATP database; it can read but not write.
Desired Future Configurations
Oracle ATP database 19c
OPC Server
Does anyone have experience using Oracle's ATP database to connect to the KEPServer EX, or any suggestions on how to solve this problem?
I would appreciate any insights.
Vishal
I would like to advise you to check the following link:
https://docs.oracle.com/en-us/iaas/autonomous-database-serverless/doc/connect-download-wallet.html#GUID-BE884A1B-034D-4CD6-9B71-83A4CCFDE9FB
It is essential to review the connection string entered in the Data Source Name (DSN) that was created. Additionally, there may be some settings that require adjustment. If we still faces issue, Please open up support ticket from mykepware.com to check into in details.
Mohit
I would like to bring to your attention an important matter regarding system compatibility and the upgrade of Kepware from version 5 to version 6. I have attached an article with detailed information on this topic for your reference.
Furthermore, I would like to inform you that older versions of Kepserverex prior to version 16 may encounter issues with Oracle 19c. Therefore, I highly recommend that if you are considering upgrading to version 19c, you should also upgrade to the latest version of Kepware to ensure smooth operation.
For more information, please refer to the following links:
1. https://www.ptc.com/en/support/article/CS348235
2. https://www.ptc.com/en/support/article/CS281944
3. https://www.ptc.com/en/support/article/CS326229
Should you have any questions or require further clarification, please do not hesitate to reach out to me. Thank you for your attention to this matter.
Mohit
Thanks, Mohit.
I have already gone through these articles. The issue is different, so here is the additional information. Oracle database 19c has two main database types: 1. a fully autonomous transaction processing (ATP) database and 2. a regular database (Enterprise, Standard, etc.). We have tried using the regular database 19c, and it works fine for us, but not the autonomous transaction processing database. KEPServerEX can write to the regular Oracle Enterprise 19c database but not the Oracle ATP database 19c.
The ATP database is fully functional, and the database user has full permission to write. We have also tested using the latest KEPServerEX version 6.17.240.0.
Vishal
Mohit
We found the solution. The details are below. I hope this will be useful for those who are looking forward to using the latest releases of the Oracle database and establishing a connection to Kepware. In addition to the below findings, we had some configuration issues with Oracle Wallet.
| Oracle Database Type | DB Version | Oracle Client version | ODBC version | SQL Developer -DB | Kepware version | Results |
| ATP | 19c | 12.2 Instant Client | 12.2.0.0 | Connected | 6.16 | ODBC driver connected; Kepware was able to read data, but writing to the database has failed |
| DB System(DBaaS) | 19c | 12.2 Instant Client | 12.2.0.0 | Connected | 6.16 | Data R/W operations were successful |
| DB System(DBaaS) | 23ai | 12.2 Instant Client | 12.2.0.0 | Connected | 6.16 | Data R/W operations were successful |
| DB System(DBaaS) | 19c | 19.25 Instant Client/19c Full Client | 19.0.0.0 | Connected | 6.16 | ODBC driver connected to DB, but data communication failed with Kepware |
| DB System(DBaaS) | 23ai | 19.25 Instant Client/19c Full Client | 19.0.0.0 | Connected | 6.16 | ODBC driver connected to DB, but data communication failed with Kepware |
| ATP | 19c | 12.2 Instant Client | 12.2.0.0 | Connected | 6.16 | ODBC driver connected to DB, but data communication failed with Kepware |
| ATP | 19c | 19.25 Instant Client | 19.0.0.0 | Connected | 6.16 | ODBC driver connected to DB, but data communication failed with Kepware |
| ATP | 19c | 21.15 Instant Client | 21.0.0.0 | Connected | 6.16 | ODBC driver connected to DB, but data communication failed with Kepware |
| ATP | 19c | 19.24 Instant Client | 19.0.0.0 | Connected | 6.17 | Data R/W operations were successful |
| ATP | 19c | 21.15 Instant Client | 21.0.0.0 | Connected | 6.17 | Data R/W operations were successful |
| ATP | 23ai | 21.15 Instant Client | 21.0.0.0 | Connected | 6.17 | Data R/W operations were successful |
