18-Opal
February 8, 2022
PDF transfer from KEPServerEX to thingworx
  • February 8, 2022
  • 1401 views
There is use case were File Transfer Need to be done between KepServerEX to Thingworx in the OPC UA. How can it be done ?
@paic @c_lowy @CarlesColl @slangley @VladimirN
Thanks.
There is an article here - "How to send data from one KEPserverEX/ThingWorx Industrial Connectivity instance to multiple ThingWorx instances": https://www.ptc.com/en/support/article/CS293840
18-Opal
February 9, 2022
Hi @VladimirN ,
The post is about sending the PDF through kepserverEx on OpcUA protocol not sending the data from KepServerEx to Thingworx !
Thanks.
