Setting Data Type and Scaling Values On Tag Using Kepware Configuration API
JK_10744682
Hi all,
Been using the Kepware Configuration API for a few weeks and am trying to create tags where I customize scaling values (need to divide value by 10).
I try to set:
"servermain.TAG_SCALING_SCALED_HIGH": 100
The tag gets created and 201 created message is given, but it still shows the default scaling value of 1000.
Wondering what I am doing wrong here and what else I need to do to get the scaling to set correctly for a Kepware tag from the API.
Any advice is appreciated, thanks!
cmorehead
(To:JK_10744682)
@JK_10744682
Please take a look at the Kepware knowledge base article provided in the following link:
Article - CS291338 - How to scale data from a PLC in PTC Kepware Products
You will see there is a dependency to set the Hi and Lo values for the scaling to work.  If the instructions in the article do not resolve your issue, I recommend opening a support ticket with the Kepware team to analyze your specific set up. Here is a link to the login page where a ticket can opened:
Log In | My Kepware
*Chris
cmorehead
(To:JK_10744682)
@JK_10744682
Log In | My Kepware
*Chris
