"Quality Changed" events generated in KEPServerEX6 ?
  • July 4, 2023
  • 866 views
I have installed KEPServerEX6 with below Activation ID for Alarms & Events.
UPGRADED V6 ACTIVATION ID :
Question : Is it possible suppress "Quality Changed" events generated in KEPServerEX6 ?
@GJ_10698072,
All of the KEPServerEX Alarms & Events are based on conditions that are separated into three categories: Multi-Level, Rate of Change, and Deviation. Each condition is dependent upon a change in value or quality. The only way to suppress an established Alarm & Event would be to uncheck the "Enable" box in the Alarm & Event tag condition configuration.
*Chris
