is there any limitation of number of Advanced Tags in KepServerEx ?
There are no limitations on how many tags can be created within the Advanced Tags plugin.
Kind regards,
Andrew Black
Senior Technical Support Engineer
Kind regards,
Andrew Black
Hi @ zajaja.
If you feel your question has been answered, please mark the previous post as the Accepted Solution for the benefit of others with the same question.
--Sharon
