Thingworx manufacturing apps extension import error
kswate
11-Garnet
I am trying to import Thingworx manufacturing apps extension. I get the following errors:
- dependencies.zip file installation results: Import Failed: java.lang.NullPointerException
 -extension.zip file validation results :internal error
kswate
11-Garnet
(To:slangley)
1. I deleted:
  • all files created in Thingworx platform except the .json file
  • files from the Thingworx Storage folder
2. Stop tomcat
  • deleted Thingworx folder from the webApps folder
3. Start tomcat
Then after I was able to import the Manufacturing Apps extension file successfully.
Thank you.
6 REPLIES 6
hrajpal
(To:kswate)
Greetings kswate,
Please share version of apps you are importing and the thingworx platfrom version .
Himesh Rajpal
kswate
11-Garnet
(To:hrajpal)
thingworx platform 8.1
thingworx manufacturing app 8.1
mapathak
(To:kswate)
Hello kswate,
Thanks for sharing the information. This is the major version i.e 8.1, we would like to know minor version as well like 8.1.1,8.1.2
Apart from this, I have a few queries:
  1. Have you refer this guide ThingWorx Manufacturing Apps Setup and Configuration Guide for Installation of Manufacturing Apps and follow all the steps/ prerequisites?
  2. Java version, Tomcat version?
  3. Is this fresh installation or an upgrade?
  4. Have you imported any other extension besides Mf Apps?
  5. Can you share Thingworx Application logs from /Thingworx storage folder?
Thanks & Regards,
Manoj Pathak
kswate
11-Garnet
(To:mapathak)
Hi
I uninstalled everything and started a fresh Thingworx 8.3 F000 H2 install using the installation guide and the system requirements guide from ptc reference documents.
I installed the following:
-java :
Windows x64 207.27 MB   jdk-8u171-windows-x64.exe
-Tomcat: 8.5.32 32-bit/64-bit Windows Service Installer (pgp, sha1, sha512)
Successfully deployed Thingworx and imported the dependencies.zip file successfully however the extensions.zip file is still failing.
slangley
(To:kswate)
Hi @kswate.
Did you make the recommended changes to the Tomcat java options (specific to Manufacturing and Service Apps)?  This information is on page 7 of the ThingWorx Apps Setup and Configuration Guide 8.3 under the section "Configure Java for Tomcat."  Remember to restart Tomcat after making any changes.
if this is not the cause of the issue, please provide the contents of the /ThingworxStorage/Logs folder so we can review further.
--Sharon
kswate
11-Garnet
(To:slangley)
1. I deleted:
2. Stop tomcat
3. Start tomcat
Thank you.
