Will Manufacturing Apps be working properly if I upgrade Thingworx?
SOLVED
RajatBain
Regular Member
I am having Thingworx 8.5.1 and for that I have imported ThingWorx-Apps-8-5-1-extension-bundle and the application is working fine. Now I am about to upgrade my Thingworx to Thingworx 9. So after upgrading will my application work fine?
Re: Will Manufacturing Apps be working properly if I upgrade Thingworx?
  @RajatBain Hello!
Yes MFG Apps will work fine with Thingworx 9.0 as well .
You need to follow the steps mentioned in the below link for the upgradation process .
https://support.ptc.com/help/thingworx/apps/r9.0/en/index.html#page/thingworx_apps%2FInstallation_an...
Gunjan Aneja
  @RajatBain Hello!
Gunjan Aneja
Hi @ganeja ,
Thanks for your information.
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
