Kepserver call Oracle procedure
tim
Hi all.
I have created MSSQL stored procedure and could successfully call it from ODBC driver with parameters.
How can I do the same with Oracle function or procedure?
Thanks.
slangley
23-Emerald II
(To:tim)
Hi @tim.
Take a look at this manual to see if it helps.  If not, you'll need to provide additional information.  What version of the product are you running?  Are you getting any errors?
Regards.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @tim.
If the previous response allowed you to solve your problem, please mark it as the Accepted Solution for the benefit of others with the same issue.
Regards.
--Sharon
