CL Data help
bmadsen
CL Data help
Pro Engineer users,
My colleagues and I have been having troubles with the CL Data on our Pro Engineer WF1 code output. As you can see in the example below, when WF1 creates the data it adds a GOTO point with the rapid. We don't know how it got there because only a couple programmers have this problem, not all of them. How can we remove this G01 move from Pro E? Any ideas are welcome.
Example:
N8 M8$
1
20>RAPID
21>GOTO /.5312,.2625,.5
N9 G00 G01 G43 X.5312 Y.2625 Z.5 H5$
22>RAPID
23>GOTO /.5312,.2625,.125
N10 Z.125$
The red is what we want to remove.
Thank you,
Brian
cncwhiz
2-Explorer
(To:bmadsen)
If you know Dave Brainsky, he can help you out. I am still on WF2.0 and he
is always my goto guy.
Thank You
Terry Thomas
Cnc programmer
Maxton Manufacturing <->
775-782-1700-253
On Mon, Dec 15, 2014 at 1:48 PM, Brian Madsen <->
wrote:
> Pro Engineer users,
> creates the data it adds a GOTO point with the rapid. We don’t know how it
> *Example:*
> N8 M8$
> 1
> 20>RAPID
> 22>RAPID
> N10 Z.125$
> Thank you,
> Brian
Brian,
It is not your CL data that is the problem. A RAPID command then a GOTO should result in the post processor outputting a G00 or G01 but not both. This problem is in your post processor. Without seeing the post files I couldn’t tell you what the problem is.
Fred Nemecek
Austin N.C., Inc.
505 E. Huntland Dr.
Ste. 370
Austin, TX 78752
512.458.1112 (x119)
512.458.5474 (fax)
fredn@austinnc.com
www.austinnc.com
cid:image001.png@01CE950F.EC4F6F80
The information contained in this message is confidential or protected by law. If you are not the intended recipient, please contact the sender and delete this message. Any unauthorized copying of this message or unauthorized distribution of the information contained herein is prohibited.
