I’m working on a tool and am unable to edit the workpiece for it. This is the error I’m seeing:
Here’s all I have under my “apps_data” folder:
Also, select "Runner" under the Mold & Cast menu and the dialog box opens, but when I click on "round trapezoid" for shape - no dialog opens... I do however see a click flash in the upper left corner of the screen that says "Menu Manager". I've tried a simple round runner and I am able to put in the diameter, but after I sketch the profile it never shows (not even in a preview).
Is something not properly installed? And if so, how can I resolve?
Thank you in advance!
Brandon
Brandon,
This is due to missing "Mold Component catalog" in your installation.
Reinstall Creo 3.0 and make sure you are checking "Mold Component Catalog" available under Customize > Application features to be installed.
Brandon,
Problem solved.
Thanks for your help.
Brandon,
Let me know if previous answer help you.
