Creo Install Files Too Large
lococnc
Has anyone else had trouble with the 4+GB file size of the latest install
files?
I find that I have to download the file from the web onto the individuals
machine, I cannot copy the file across the network or from a thumb drive.
Inevitably the zip gets corrupted.
3 REPLIES 3
dustin
(To:lococnc)
I have noticed that as well. I assumed that the download itself was corrupted and have yet to get Creo 2.0 installed on any computer. I didn't think to unzip from the download computer. I previously had issues with the download size. It appeared not to get all the data. I will try to download again and work from the root computer and see what happens.
Are you using the windows unzip utility? I have found that is the issue and if you open the file with a program like winzip or winrar it opens fine. Save you some time trying to redownload it.
In Reply to Michael Gamber:
files?
dustin
(To:lococnc)
You are correct Greg. I found that it didn't matter how I moved or copied the zip file around, the windows zip utility would view it as a corrupt file. I have 7-zip installed on my computer, so I tried that and it unzipped just fine. I now have Creo 2 up and running. Thanks Greg.
In Reply to Greg Scorpil:
