How to change the cut-distance generated when using "rot fix" when placing an ejector?
cfrederiksen
3-Newcomer
Hey everybody,
When i place ejectors using EMX, the cut which is generated is always very close or coincident with the ejctor shaft. See pic:
This makes it difficult to add a champfer in the hole.
I would like the distance from center of ejector to rotfix surface to be bigger. See below pic:
Where can i find the parameter file, from which i can increase this distance??
Best regards Clement
Creo3.0 M040
EMX9.0 F012
2 REPLIES 2
Hello Clement,
If you have a look to the Component Dialogs bottom area you will find the dimension OFF which is responsible for your described issue.ejp_rotfix1.PNG
In the last column you will also find a RULE which presdefines the OFF value depending on the DM3 Diameter: In this case 0.5*DM3.
This rule is set up in the udf_data.txt file, which can be found here: <emx_intall>\components\mm\ejector\udf
In my example I assemble an ejector pin which uses the template: "ejector_2.prt"
In the udf_data.txt all udfs used for the template type "ejector_2.prt" defined in the Section EMX_UDFS (See picture below)
You will find the udf EJP_CB_FIX1_2 which ist responsible for the cut out of type Rotfix1
The rules for this UDF are defined in the udf_data.txt a bit further bleow in the the section EMX_UDF_VALUES
You can now either change this rules to maybe to 0.6*DM3 or what ever you like.
Be aware that if you install a new blank EMX Version all these cahnges will be reset to default.
You can use alternativly set the Windows enivroment variable EMX_USER_CONFIG_PATH to point to a custom EMX configuration path there you can place the configuration and the components folder. I recommend to track your changes to the config otherwise future users wont now what was changed and this can cause unexpected behavior.
Regards
Thomas
Kind Regards
Thomas Schneyer
B&W Software GmbH
Thanks for your feedback Thomas! Great, just the information i needed.
Regards Clement
