how to retract the tool after every pass completed in pro e milling ? either volume milling or trajectory milling
sounds like defalut behavior for Pro E ![]()
Here is the option for traj milling
And volume milling
Hi Thanks for your reply.
Still I dont find the anwer I couldnot find your solution in the trajectory milling parameter.
Pls find the image for your refernce .
Pls share parameter list what you have enetered for proe trajectory milling
Or pls create a model & share it to me ( -)
