I need 4 sliders for my tool
I select the slider option, put the dimensions and place it at the required/selected point/location. Is it possible to use the same dimensions for the other 3 sliders without the need to manually change the dimensions every time so that i just have to select only the placing location for the rest 3?
Yes, you can use the Functionality Assemble again or Assemble as Copy
Simply select the reference of the previous slider and you can place the same component again
Note: The difference between Assemble again and Assemble as Copy is important.
Assemble again means the exakt same component is assembled. In case you modify or delete one of them, all others will also be modified or deleted. So all components are linked to each other
Assemble as Copy meansthe components are created equaly but in case you modify or delete one of them the other components will not be deleted or modify. The compoenents are not linked to each other.
Kind Regards,
Thomas
