Write permissions issue
davehaigh
I'm trying to install onto a mounted drive, from my Windows 7 machine, and Creo is telling me that I don't have write permissions to the folder.
I'm doing the same thing from my XP machine, to the same mounted drive, right now. Same user, same permissions. Windows 7 is trying to protect me from myself.
I'm running the Creo installer as administrator on the Windows 7 machine. (I am an administrator on the local machine and the remote machine. I have "full control" permissions on the shared folder.)
Any ideas????
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
mkelley
2-Explorer
(To:davehaigh)
Just a guess - but I'll bet you $0.05 that you are encountering Windoze DEP (Data Execution Protection) issues...
Run the Installer with the right click Run as Administrator
Also be aware that if you use c:\users as you user folder then this may cause issues under windows 7 as it now has a c:\users which is protected by the os
