Hi everybody,
Anybody knows how to add transparent colors to the technology colors?
Best regards Clement
Hello Clement,
What version are you working with?
This functionality is available in the latest releases EMX9 M012 and in EMX8 M026 or higher.
Simply edit the file color_definition.cfg in the configuration folder.
You can add a 4th coloum for each technology color between 0 and 1 to set up the transparency.
Regards Thomas
Hello Thomas,
Thank you for your answer.
We´re using EMX9 M010...
I just updated tha color definition file per your suggestion and it does not work.
I guess we need an update of the EMX then. Could you provide us with an update? M012...
Kind regards
Clement
