I am licensed for 8. How can I download 9?
Your Prime 8 should allow you to convert the file.
You don't need Prime 9 for that.
Starting from the 7th version of Mathcad Prime you can use the built-in converter (before the installation process, it is necessary to select it among the installation components).
Correct link - "Mathcad Downloads": https://support.ptc.com/support/mathcad_downloads.htm
