Did anything on your PC change? You should be aware that your Prime license is tied to the (primary) MAC address of your internet connection. Did you get the license while connected via LAN to internet, and are you now only using Wi-Fi (or vice versa), or did you change LAN or Wi-Fi interface?
You wrote you have a (student) license. You should then be able to locate the license file and read it (don't edit, let alone save it with edits). Just read and check the MAC address for which the license applies, and check that that is the MAC address of your current internet connection.
The license file does contain a different MAC ID. The mac ID in the license file does not seem to exist on my system or any connected devices. Initially after I activated the software the license file worked for couple of weeks. I don't understand how the wrong mac was picked up. I will have to follow up with PTC and see if there is a way to rectify this issue.
Thank you for your help.
