I am using Mathcad Prime 7.0 7.0.0.0
Program crashes due when inserting a combo box
Here are the errors that I faced
An Unhandled Exception on the dispatcher thread
Hello @ShayJ,
Try to rename PTC folder under C:\Users\%username%\Appdata\Local\ to ptc.old
Launch Mathcad Prime and check if that resolved the issue.
Else:
Hope this helps
Vipul
Good day Vipul,
Thank you for the response. Our IT specialist has tried the steps you have provided, but Mathcad is still crashing. As far as I can tell it is only when I insert the combo box that causes the application to crash. All other operations work fine.
Thank you.
