I just loaded Prime 8 on my computer which also has Prime 7 amd Mathcad 15 installed and running. When I went to convert a MC15 file using Prime 7 the XCMD function is greyed out on Prime 7 but not Prime 8. Since once a file is converted with Prime 8 it will not open with Prime 7. Some collegues use Prime 7, how can I produce a Prime 7 conversion file?
Read this thread: https://community.ptc.com/t5/Mathcad/XMCD-MCD-Converter/m-p/752544#M197640
I think the best way is to have one of your colleagues with Prime 7 do the conversion.
Luc, Thanks for the comments and suggestive resolves. However I have tried to reload Prime 7 with Prime 8 already laoded to obtain XMCD converter to install on Prime 7. It remains greyed out.
The other comment to have other colleagues convert won't work as I am the author of the original work.
Steve
I have the same issue but I also have prime 5 and 6 which can do the convesion. I convert with 6 and then open with Prime 7 and save.
If you have older versions this is a workaround.
