Is there any way of plotting a function with the variable on the y-axis and the function on the x-axis, instead of the "normal" way?
In the appended example, the "rotated" plot only plots the first ~10 m or so, then it seems to stop.
Thanks in advance
Setting h to 500 in the y-x plot only sets the vertical scale of the plot, unlike in the x-y case where it sets the range of h values as well.
To get what you want, simply declare a range variable h:=0,1..500 before the plot.
Thank you Stuart, worked just fine!
Ingen orsak. 🙂
