Do you have any ideas to solve the problem of 3D Plots of Mathcad 15 in Windows 8?
Hello I had the same problem.
Use A high Contrast Theme. and then restart Mathcad.
And it will normally run and draw 3d plot.
I've just tested that myself on corporate Win7 PC and it works in the case where a scroll made the 3d plot disappear, and then a click inside makes it re-appear.
Further, I did NOT need to restart mathcad. I could just right click the desktop, select the "personalise", then scroll down to the Basic & High Contrast Themes, and select one (usually classic), and on applying the theme, Mathcad worked right. I could change the theme again (back to one of the fancy ones) and Mathcad (still running) would stop doing the proper re-draw!
So yes it works.
Just got to check a colleagues machine (slightly older / different graphics card) to see if it works for him.
see also this other thread that I started blank 3d plot - PTC Community Its a nice link back 😉
