3D plots
hw3
3D plots
Hi all
I'm pretty new to Mathcad so am just learning the ropes. I'm having trouble with creating a 3D surface plot of a function with two variables. Can anyone see where I'm going wrong?
Thanks in advance
Ben
StuartBruff
23-Emerald V
(To:hw3)
Ben Fulford wrote:
Hi all
Thanks in advance
Ben
Ben
The 3D plot algorithm defaults to a range of -5 to +5 over both axes. This results in complex numbers when applied to Npmelt - hence the complaint. You need to manually set the range you want in the 'Quickplot' tab on the 3D plot dialog or use CreateMesh to generate the data. I've attached a worksheet that uses a variant of matrix to create the Npmelt array.
Stuart
5 REPLIES 5
StuartBruff
23-Emerald V
(To:hw3)
Ben Fulford wrote:
Hi all
Thanks in advance
Ben
Ben
Stuart
hw3
(To:StuartBruff)
Thanks for your help.
Unfortunately, for some reason I can't display the 3D plots. They don't even display in the Quicksheets. Is there a setting I need to change somewhere?
StuartBruff
23-Emerald V
(To:hw3)
What version of Mathcad are you using on which operating system?
Some people have reported similar problems that have been cured by either turning off borders around plots - I don't recall them on your worksheet - or turning off hardware graphics acceleration.
Stuart
hw3
(To:StuartBruff)
I'm running Mathcad 15 on Windows 7. Borders are off.
Ben
hw3
(To:hw3)
Ah, now borders are off and everything's working great.
Thanks for the help!
