4x4 Magic Square.
lvl107
20-Turquoise
4x4 Magic Square.
Hello, Everyone.
Is it possible to solve M matrix, the above ?
   Thanks in advance for your time and help.
       Regards.
LucMeekes
(To:Werner_E)
One can get quite far though:
It's just that the inequality constraint (involving M01 and M03) is not obeyed. Note that I first tried:
But then I got an error message saying it's not allowed inside a solve block.
6 REPLIES 6
LucMeekes
(To:lvl107)
At first glance: no
Reason: your system is over-constrained. You have 16 variables to find, you can have only 16 constraints.
The requirement of a magic square (sums of all 4 rows and of all 4 columns and along the 2 main diagonals must be equal) already gives you at least 4+4+2-1=9 constraints. Now you've added 16 more constraints, totalling 25.
Another constraint from the magic square is that all your variables must be different AND in the range 1 through 16.
-MFra-
(To:LucMeekes)
(To:lvl107)
Apart from what Luc already wrote you would have to constraint the matrix elements to be integers - something which Mathcad is not really good at.
So I guess the better option to get a magic square is to write a program following one of the algorithms to build a magic square. There a quite some in print, ususally differing according to the magnitude of the sqare, distinguishing odd or even order and as far as I remember ther is a short algorithm dealing with squares of a mgnitude which is divisable by 4.
What exactly ist the problem you should solve for homework?
WE
LucMeekes
(To:Werner_E)
lvl107
20-Turquoise
(To:LucMeekes)
  Thanks for your time and help, Werner and Luc.
  I have just realized my question at the moment about :  Pandiagonal magic square - Wikipedia, the free encyclopedia
   Is it possible to solve COMPLETE MAGIC SQUARE, and How many solution in this case ?
       Best Regards.
            Loi.
lvl107
20-Turquoise
(To:LucMeekes)
  How many solution else for COMPLETE MAGIC SQUARE does it have in this case ?
  Thanks in advance.
       Regards.
            Loi.
