A little symbolic problem
  • January 22, 2019
  • 2 replies
  • 2540 views
Hi, I met a little problem and hope for your help.
How to overcome this behavior without manual intervention?
MC15 File is attached
Best answer by LucMeekes
You have to differentiate (name differently) between the X as parameter of the function, and X as the vector you defined before.
Within the definition of the function u, the best(closest) known X is the parameter of that function u, that is X, which at that point is unknown to be a vector...
23-Emerald I
January 22, 2019
Try vectorizing your expression:
ifomenko1-VisitorAuthor
no result(:
LucMeekes23-Emerald IVAnswer
maybe that way:
