Moving to Mathcad Prime 9 from V15, and noticed there are no rules or guidelines to align the different regions of the document.
Any suggestions/tips/tricks to align the regions other by eyeballing them?
The curser snaps to grid. Does not matter if grid is showing or not. You will get used to aligning by the snap to grid.
In Document | Page | Show Grid you can set if grid is showing or not and the selection of standard or fine size grid.
Most people in the forum use standard grid size.
Cheers
Terry
Cheers
Terry
The second post was not intentional. This happened with another post of mine as well
Hi @TD_11399801,
Anurag
