Automatically selection Table value
smilani
6-Contributor
Dear all,
I would to create a calculation sheet in Mathcad 15 where when I select an option the reference value are automatically selected.
For example:
In the previous table I would select the value determined by weld condition (full penetration) and quality level 2.
I would to create  a windows that, when I select this two condition, the referring value is automatically selected.
Best regards
Stefano
8 REPLIES 8
LucMeekes
(To:smilani)
What do you define as the 'reference value' or the 'referring value'?
If in table 5.12 select 'Full penetration' and a quality level of 2, I still have to choose a surface condition between 'Machined' or 'Welded' to arrive at a single Fatigue strength reduction factor.
smilani
6-Contributor
(To:LucMeekes)
Hi Luc,
I would create an automatically option into Mathcad to select the reference value. I mean the output value obtained by the input selection.
For the example in table 5.11 if I set Weld condition (full penetration) and surface condition (machined) and quality level  1 that are the input data, I would to automatically obtain the ouput (reference) value equal to 1.
Stefano
LucMeekes
(To:smilani)
But then, you might be looking for something like this:
smilani
6-Contributor
(To:LucMeekes)
Is possible to obtain a similar results with control command Immagine.png?
Stefano
MJG
18-Opal
18-Opal
(To:smilani)
I was just working on such a solution for you:
With this in a hidden or non-printed region:
File attached.
smilani
6-Contributor
(To:MJG)
Is that I request
Thanks.
How can create it? do you have any indication for me?
Regards
Stefano
Mark attached a file that you can download.
It's in version 15, I don't think Prime has controls yet.
DJF
(To:smilani)
This is how I did it in Prime.  I assume something similar works in 15.  Note the use of strings.
