Calculation of mixture amounts
  • September 11, 2006
  • 2 replies
  • 3701 views
Collab,
This is probably a simple calculation for a chemist, however, I am a bit baffled. The mix, as it were, will be Component A plus 3 solvents:
Component A is a dispersion of silicone, 50% by weight, specific gravity = 0.861
Component B is a solvent, specific gravity = 0.712, 34% w/w of the mix
Component C is a solvent, specific gravity = 0.78, 35% w/w of the mix
Component D is a solvent, specific gravity = 0.79, % adjusted to get final dispersement % of Component A
The question is: How to mix using volume measure to obtain a 2% (w/w) dispersion of Component A in 10 ml total volume of mix?
Art
23-Emerald V
September 11, 2006
On 9/11/2006 6:00:46 PM, ArtZ wrote:
== This is probably a simple calculation for a chemist, however, I am a bit baffled. The mix, as it were, will be Component A plus 3 solvents:
== Component A is a dispersion of silicone, 50% by weight, specific gravity = 0.861
== Component B is a solvent, specific gravity = 0.712, 34% w/w of the mix
== Component C is a solvent, specific gravity = 0.78, 35% w/w of the mix
== Component D is a solvent, specific gravity = 0.79, % adjusted to get final dispersement % of Component A
== The question is: How to mix using volume measure to obtain a 2% (w/w) dispersion of Component A in 10 ml total volume of mix?
Being even more baffled and not understanding the significance of the silicone dispersion "50% by weight", does the attached hold any clues?
Stuart
September 12, 2006
Stuart,
Thanks for your reply. The significance of "Component A is a dispersion of silicone, 50% by weight," just simply means that the available solute is 50% available.
With this in mind, for a 2% yield of component A (the solute), the "percentage weights in mix" as you called it, would change from 2% for wA to 4%.
Otherwise, seems your calculation is spot on. It's interesting that in reality, the problem is quite simple, yet I and several others made it out to be more complex than it is.
Thanks for the reality check.
Art
On 9/12/2006 12:00:58 AM, ArtZ wrote:
>Stuart,
>it is.
>Art
___________________
Art,
You should be able to define an objective function and a criteria function depending upon the objective function ... then Minimize the criteria function.
Thus, you will have a simple logical approach that will suit up to 200 components (?), in an elegant simple steps.
jmG
Art,
There are lots and lots of chemicals sheets in the web.
at least visit Mike griffin.
jmG
