A small program that takes the first three points expressed as vectors and calculates the equation of that plane defined by those three points.
Program then calculates the distance from the fourth point represented as a vector from the plane of the other three.
If the distance is zero the four points are coplanar. If there is a positive distance then points are not coplanar.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
