Conditional function error
Lurky
As part of my coursework, I have to calculate the self-inductance of a single turn coil.
We have been provided with a set of nested equations to estimate the value, which have been presented in mathcad format.
However, when I tried to type in the equation, I got an error telling me the final "otherwise" statement needs to be matched with an "if" statement.
Could someone please point me in the right direction?
VladimirN
(To:Lurky)
At you function "otherwise" is used not correctly (not for all expression, but only for the last item).
8 REPLIES 8
FDS
(To:Lurky)
Greg, most likely you did not use the "otherwise" from the programming palet
VladimirN
(To:Lurky)
Lurky
(To:VladimirN)
Thanks. I didn't realise that I added the "otherwise" in the wrong order.
VladimirN
(To:Lurky)
You're welcome.
I use in same cases if-function:
That is an interesting suggestion. I was unaware that you could nest if statements like that.
Thanks. But I think the best solution is - see the picture:
I agree
Mike
