I have attached a v11.2 file that doesn't convert fine and maybe more important it does not calculation when I have fixed the conversion.
The converter leaves the guess values out side the solve block, but on the other hand I can't see no way a converter can figure out what has to go inside the box or not. So it leads to the thought that a solve block can replace a given/find from the beginning has been a mistake. And then what? Are we going to have a given/find structure back in version 3 of Prime or can my idea of user interactive sequence be a solution?
Actually I was in doubt where to start the discussion with a subject "Bugs to be fixed" but then there would be too much. So this is just about this specific issue.
