Hello, Everyone.
Creat a program function RLL( ) ?
Thanks in advance for your time and help.
Regards.
Message was edited by: Loi Le
You may use an "unravel" program to use Freds routine:
Or how about this:
What is the question?
I'm sorry because my question is not clear, Mathcad User. ![]()
I guess Werner who did help me answer some my questions in some previous posts, but the last question I need help is :
The question is "Create the program function F( ) ?
Best Regards.
Many thanks for your time and help, Fred. ![]()
Could we edit the program F( ) ?
Best Regards.
The function "str2num" converts letters to ASCII numbers. The function "num2str" converts ASCII to letters. Those will work inside F().
F() as written, works on a vector, not an array. Select either a row or column.
Or how about this:
Thanks for your time and help, Werner.
Best Regards.
