>I still would have liked to understand what jmG was about<<br> __________________________
I have explained why you don't have a solution , because you don't have a DE, because you can't equate components or terms. Conclusively you can't "isolate the highest derivative" [Mathcad is telling you that in the error message]. If you don't trust what Mathcad, Mathematica are saying ... same in different words, then try Maple or else CAS solving DE's.
A DE represents the infinitesimal components of a system. For it to be solvable by symbolic or numerical solvers, components must "equate". It then implies the highest order derivative must exist. In your representation, it does not exist by inspection , Mathcad error message confirms. The Mathematica error message tells differently "input is not an ordinary differential equation".
Your representation is either incomplete or incorrect. If you figure you have something and wish to be checked, post it. I'm not saying your project is not solvable, NO ! Simply that some steps are missing to arrive at a solvable DE or that your representation needs be transformed or completed.
![](/upload/DE02.gif)
If it does not help, just discard.
Mathematica solves example 2, Mathcad does NOT.
Can you trust what Mathematica is telling about your input ?
jmG
