On 2/4/2009 8:47:20 AM, blckwtr wrote:
>Is it possible to change from
>the default unit in a 2D plot?
>Let's say; from m^3/s to
>liters/min.
>In many plots this would be
>much easier for presentations,
>especially where the unit
>isn't in a power of 10 or
>10^-1...
>Thanks..
>Tommy
______________________________
>If Mathcad has a direct correspondence in the list of conversion, it is only needed to plug the desired unit in the left black place holder of the result, it does the conversion and displays the "UnitSystem" it is converted to. For the plot: simple, define the conversion factor.
So simple ! and no need for horror plots.
Here the first result is : qualified, quantified, coherent ... if the conversion exists in Mathcad, the new result is automatically: qualified, quantified in the converted coherent new system. If Mathcad does not have the built-in conversion, just a matter of creating it. Easy to check if the conversion exists, like demonstrated, but better check with source converters !!!! <<br> ......................
Tommy,
Just like this: elegant, as it should be & visually traceable.
![](/upload/Unit50.gif)
jmG
