Best answer by Werner_E
Assuming you want to use the solve block, would the following help?
Your b=1 needs no solution, it is what it is, it can be used to solve s as a function of c, or the other way around.
This is how it should work:
Or were you looking for this...
Werner_E25-Diamond IAnswer
bhg19931-VisitorAuthor
Thanks for your solutions. Yes, it was a fast example and b=1 makes no sense.
