Hi again!
I'm trying to solve the deflection of a beam with a constant load along it's length.
I have a differential equation of 4th degree with four initial conditions.
The moments in the bearings are zero and the deflections as well.
Now my question is: Why don't i get a solution with "Gdglösen" in MC15 although i initialized four conditions?
Error Message: "to few conditions"
Any help appreciated!
Best regards, Volker
...next step will be: Solve the same task in MP4 with Units.
Impressive!
but when asking for y(lo/2) (at the end of the sheet) i get again an error message.
Now the same problem in MP4:
And why do i get no solution here?
Delete please operators on the right part of the sheet
Thanks, Valery.
MC15 beam bending now works-although without Units.
Now i want to have it complete - with Units-, see attached sheet.
Why do i get here no solution?
Sorry - I have not Prime 4.
