Derivative of an Array
belt_sander
I have a body of data for position and time (constant time interval),
and I would like to take the derrivative in order to get the speed. Is
it possible to do this with MathCad?
>time interval),
>the speed. Is
>MathCad?
_____________________________
No problem, fit first the data in order to get an analytically exploitable function, whether an approximation or a model. You can do it otherwise using the finite differences, but that won't filter/smooth the data.
jmG
For a few points data set, assumed as something like exact points without error, check in the "Quicksheets" under "Data Analysis" the entry "Differentiation and Integration of Data Vectors".
For disperse data with more or less error (a cloud of points) check, also under "Data Analysis", the related entries about fitting techniques like linfit, power fit, etc.
Regards. Alvaro.
