Derivative of magnitude function
  • November 4, 2016
  • 2 replies
  • 1649 views
Hi all,
please refer to attached files (Prime and Mathcad versions).
I have a 3 functions:
1) Ha(s,...) - a filter function (not really important what it is)
2) M(s,...) - magnitude of Ha(s)
3) D(s,...) - derivative of M(s)
When I plot M(s) and D(s) with s replaced with iw, I would expect to see the derivative function have a value of 0 when the magnitude is at turning points but this is not the case.  Can you spot my error?
D.
Best answer by -MFra-
Hi David,
As you can see from the chart, the derivative of the module is zero at the peak.
-MFra-21-Topaz IIAnswer
Hi David,
DaveWooff10-MarbleAuthor
Hi F.M.,
got it. I guess the problem was in differentiating w.r.t. 1i.w but anyway, Many thanks.
D
