Difference in results between excel and Mathcad
dipeshchauhan
Hi ,
I have a Implicit equation to solve , but with the same set of the parameter value i am finding two different curve.
The way i am trying ,
  • Use Excel to iterate by resolving it's circular reference
  • Using Mathcad solver block (Given and find)
Please help me in that.
11 REPLIES 11
Mathcad 11 ver. file attached
Your Mathcad formula was wrong - be very careful where you put your brackets!!
Alan
RichardJ
(To:AlanStevens)
The Mathcad one or the Eccel one? I found the same thing, but assumed that the one in Excel was probably wrong.
AlanStevens
(To:RichardJ)
I think it's the Mathcad one that is wrong as the value of I at V=Voc should be zero. Also, there were differences in the values of Rp and ekt used between the Mathcad and Excel worksheets, though I think the misplaced brackets provided the major source of error.
Alan
RichardJ
(To:AlanStevens)
OK. I don't even know what Voc is, and based my assumption on the fact that it's orders of magnitude easier to screw up a formula in Excel than it is in Mathcad.
Yes, I also saw those, but changing them makes little difference. As you say, it's the brackets that are the real problem.
AlanStevens
(To:RichardJ)
Nor do I, but in an earlier post with the same system Dipesh mentioned that I should be zero when V=Voc.
I totally agree with your comment about Excel - in fact, the equation written in cell C5 of the Excel spreadsheet is dfifferent from the ones actually used in the calculations (there's an unmatched bracket). I suspect that the Excel spreadsheet was developed first and then the formula (mis)copied into Mathcad.
Alan
RichardJ
(To:AlanStevens)
We seem to have gone through almost exactly the same exercise! I've deleted everything now so I can't check, but I think there are actually three unmatched brackets.
LouP
(To:RichardJ)
Assuming that Voc has its usual elect. eng. meaning - open circuit voltage - then by definition the current should be zero at this value, so it is a reasonable assumption. I didn't check this in the mathcad sheet, so its formula may well be wrong. I agrre that the Excel syntax has errors, but I don't know what's correct. One thing I did check, and that I recommend to anyone (Dipesh : - ) solving any complex nonlinear equation is to check the solution. Whether the matchad equation is wrong or not, the solution found does satisfy the equation. I set up a fct. to eval the right side of the equation as a fct. of V and I, then checked to see if this gave the value I on left side. It did. Worth checking if solved in Excel, too.
Lou
RichardJ
(To:LouP)
Thanks for the clarification
Thanks Allan , My problem is solved now. It is "bracket" problem .
I should have notice it, but any way thanks .
DONT USE EXCEL !!!!!!!!!
http://communities.ptc.com/servlet/JiveServlet/showImage/38-1286-6356/thwack.gif
Mike
