Different results of the calculation "genvecs" function?
VladimirN
In Mathcad 11.0a:
In Mathcad 15 M040:
In Mathcad Prime 3.1 F000:
It's just that the M11 eigenvectors have been normalised to 1, whereas the M15 and Prime values haven't.  If you take each column of the M15 and form the square root of the sum of squares of each of its numbers, then divide each of the numbers in that column by that value, you get the M11 result.
Alan
Alan
Alan,
Thank you for for an explanation.
