Display angle in degree instead of radians in plot
SFares
In my plot, i am showing the angle in radians(X-axis). how can i display it in degrees w/o changing the plot? Thanks!
StuartBruff
23-Emerald V
(To:SFares)
Divide the angle by 'deg' in your x-axis (not the y-axis as you will still be calculating in radians) and change any fixed limits in your plots to reflect the value in degrees.
StuartBruff
23-Emerald V
(To:SFares)
SFares
(To:StuartBruff)
it did not work unless i did not do it correctly
RichardJ
(To:SFares)
You need alpha/deg on the x-axis, with the upper limit set to 10. It works, because I just tried it.
SFares
(To:RichardJ)
Thank you !!
