Error in computing the polyroots
vveeran
Hi all,
I want to compute polyroots for the example program which I attached below.
But, I am getting some error in computing the polyroots.
Please help me to find out roots for my example program.
Also, I need to plot Real and Imaginary part of poles of the
given example program.
-MFra-
(To:-MFra-)
I'm sorry! I provide immediately. But also the F. Kolepp solution is of some merit.
About your question:
1) When looking for a symbolic solution, you have to reset all the variables and constants involved. Otherwise you will not get a symbolic result, but a numeric result.
2) That is the symbolic solution of the equation included in the "Given-Find" block.
3) simply replace the quadratic equation with the third degree where there is the symbolic operator "solve".
Bye
7 REPLIES 7
(To:vveeran)
polyroots is a numeric function bit your coefficients include the LambertW Function which in Mathcad is only known by the symbolics. Thtas the reason for the error.
vveeran
(To:Werner_E)
Dear Werner,
Could you please correct the error of my program
and find the roots of my given program,
So that it will be helpful to me.
Thanks.
-MFra-
(To:vveeran)
I would do so, I do not know if that's what you want
vveeran
(To:-MFra-)
Dear F.M,
Thank you for your reply.
That is what I needed.
Could you please attach the code.
could you please explain,
why did you initialized like this,
gamma1= gamma1, x=x , beta1=beta1
what is the meaning of this,
ans(v)->LambertW((v^2*beta1/20)v + beta1(v)*gamma1(v)) / beta1(v)
Similarly,
If suppose I have cubic roots like,
a3(v) s^3 + a2(v)s^2 + a1(v)s +a0(v) = 0
where a3(v), a2(v), a1(v) and a0(v) are coefficients.
How to compute the roots by using the above procedure.
-MFra-
(To:-MFra-)
Bye
If you convert v from a range to a vector you can make your sheet work.
See attached.
vveeran
(To:Fred_Kohlhepp)
Thank you all
for your replies.
