Lookinag at all the messages perhaps the solve block is not going to be able to do what I would like it to do.
I will try to explain the project further. The class is called EOR (Enhanced Oil Recovery). Also for the record I did one class with Mathcad a year ago so definitely a little rusty so I don't doubt I am doing some things wrong.
For part one of this homework we were asked to design 1000 capillary tubes. Basically 1000 cylinders with an assigned geometry. My geometry was a scalene triangle with angles 40,60,80 and with a length of 30 micron.
For the assignment we were suppose to generate a list of 1000 random x values and then use it is in the first equation calculate the inscribed radius for the triangle. From that we were asked to calculate the perimeter, cross sectional area and volume of the triangle.
This was all for part one of the homework and I have put in big bold letters end of part 1 of homework mostly so I could recall where section 2 started.
After that our teacher has asked us to calculate the capillary pressure or Pcow for each of the 1000 tubes.
His flow diagram was to guess an initial Row value which is the radius of the oil water interface. The Row guess value is needed to calculate Aw, Lws, Low or equations 1,2,3. I then need to take the results from 1,2,3 and calculate equation 4,5,6 this will give me Ao,Los,Low. With these values I can calculate Pcow or equation *. Equation ** is used to confirm that my initial guess of row was accurate.
I have done the manual iteration below by limiting table values and then manually guessing it. The provided method or flow chart by our teach does work. I just am hoping that someone in mathcad I can get it to do that with 1000 values.
An accurate initial guess for row is equal to the inscribed radius calculated at the top.
So basically my initial guess for all values of row := R where R = inscribed radius calculated in section one of the sheet.
I do realize that in my solve block I have 8 equations and have only provided one initial guess and that is where my problem is. But all the equations are needed and my initial guess for the other variables will vary based on which row I am guessing.
I hope this helps some more. Attached is a mathcad 11 file with units in it.
jmG I really appreciate your help in actually rearranging some thing in my mathcad file and will most likely make some of these changes. For now I know that manual iteration works so I am hoping to stay with it for the time being.
If you have any more questions please feel free to ask.
I am realizing that maybe a solve block is not the way to do this problem if that is the case is there a better way to do this?
