I'd like to know if installing Mathcad 15 in Windows 10 goes smoothly. Has anyone had recent experience?
Jim
I had Mathcad 15 on both a Windows 8.1 and a Windows 7 machine. I upgraded both to Windows 10 and have not had problems with either one.
I don't recall having big troubles installing Mathcad 15 on Windows 10. But do make sure you have the right version of MsXML installed. I believe that depending on the Mxxx version of Mathcad 15 you may need either version 4 or 6 of MsXML. See here for a possible download link MSXML 4.0 SP3.
{You can and should have both version 4 and 6 installed on the same machine if you have have one software that requires 4 and other that requires 6.)
I'd say: go ahead and come back here if you encounter any problems.
Thank you, Lawrence and Luc. It sounds positive, so I'll give it a try.
Jim
