REF: http://www.ptc.com/cs/cs_26/howto/beh12103/beh12103_a.htm
Can anyone that has used the Mathcad Analysis feature in Pro/E please raise your hand?
In your response, please state whether you predominantly pull data from Mathcad (mc2proe), push data to Mathcad (proe2mc), or use a combination.
Comments about positive and negative experiences with this functionality would also be appreciated.
Using Wildfire 4. Considering Mathcad, but management says that there's no benefit. On a "fishing expedition", looking for the "big one" that might get them to change their mind.
Andrew,
There is a good reference book available if you are planning to use MathCAD. The title is Engineering with MathCAD by Brent Maxfield. Unfortunately, it does not discuss the MatchCAD / Pro-E integration, but is very helpful tutorial in teaching you how to use MathCAD to solve engineering equations.
As I am currently off PTC maintenance, I cannot view the link you posted to the PTC website. It would be helpful if a book was available with tutorials on the Pro-E & MathCAD integration.
Chris
In Reply to Andrew Kelly:
I just received this tip about a user guide that covers the the MathCAD integration with Pro/Engineer.
Tristar has a Mathcad Quick Reference Guide available that basically does what you’re asking about.
Andrew,
Chris
In Reply to Andrew Kelly:REF: http://www.ptc.com/cs/cs_26/howto/beh12103/beh12103_a.htm
