I am trying to do a finite difference to solve the differential equation and compare it with the analytical solution. I am not sure why I am not getting the plots to work out. I attached both Mathcad-15 and Prime 7 files. I converted 15 to Prime7.
Thank you,
Sam
Problem:
Using Odesolve:
The finite difference:
And the analytical solution is:
Plot:
Problem:
Using Odesolve:
Plot:
Thank you so much Luc!
Sam
