jmG
Sorry, Jean. Yours fittings are fine, but they have no relation to chemical kinetics. The estimation of rate constants always is based on kinetic model of process. This model is formulated on the basis laws of chemical kinetics.
Viktor
Viktor
Yes Viktor, I will try the MinerrOdesolve based on the system proposed by Alan & Fan. This site is so inefficient that it reduces a chunk of the time that could be spent on the work itself. So nice you are back from Russia ! You are right, it should be called "Fitting models" only . I wanted to make sure the originator would catch the work sheet. What I do on work sheet for collabs, I repost as a new "Discussion" because the work sheet can't be reposted because of the stupid *.zip
Cheers Viktor, Jean
jean Giraud wrote:
... I will try the MinerrOdesolve based on the system proposed by Alan & Fan.
See my mathcad files (MC14): http://communities.ptc.com/message/151014#151014
Thanks!
